where do ground wires go on coil??
Old Feb 24, 2003 | 12:30 AM
slashz28's Avatar
hi guys k, you know you have that "triple ground" that goes on the stud on the coil? k, i put that between the coil bracket and the stud (not between bracket and head), is that the right way? now , theres another "ground" wire, the wire itself is black (not to be confused with the brown one) and it goes on the same stud on the coil bracket as well. only question is, does it go together with the "triple " ground? does it go on by itself, with another nut on the stud? or maybe does it go between the head and bracket? sorry if its a bit confusing, but the answer should be simple thanks a bunch as always
Old Feb 24, 2003 | 12:58 AM
drop top steve's Avatar
On my 97 the icm/coil bracket is held down with two studs, then a star washer, the three ground wires and then a nut. I used a 1/8 spacer between the icm bracket and head to help keep temps down.
Old Feb 24, 2003 | 01:31 AM
slashz28's Avatar
thanks for the reply drop top but what about that other wire that goes there as well? its a single ground (black wire). does it go together with the triple one? or does it mount on top of the stud with another nut? thanks
Old Feb 24, 2003 | 03:35 PM
slashz28's Avatar
does anyone know?? thanks
Old Feb 24, 2003 | 04:13 PM
On the stud nearest the AIR pipe, mine has 2 tan looking wires together on one ring lug, one black wire on a ring lug and one braided ground strap that goes to the chassis. All of them are between the outer nut and the stud.
Old Feb 24, 2003 | 04:47 PM
slashz28's Avatar
thank you
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
PCLZ28
Dec 24, 2015 05:19 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Injuneer
Dec 15, 2014 09:36 AM
kandied91z
Aug 6, 2002 01:18 AM
