ALL LT4 CAM kit guys in here!!!
Originally posted by chodieeas
12.83@109.67 in the 1/4 8.20@87 in the 1/8th. 335rwhp and 349rwtq uncorrect and 327rwhp 339rwtq sae corrected with mods in sig.
Chris
Chris
If you decide to use the Hotcam I would recommed buying a better set of srings than the LT4 springs that come with the kit. I have seen these springs break.
They are the same springs used on the LT4 cam in the corvette. Which the LT4 cam is smaller (not by much) than the Hotcam. Crane or Comp Cams make good springs for our LT1's . You want springs that will handle atleast a .550 lift. It is better to be safe than sorry. By the way 12.89@103 in a 4500 lb boat. Good luck
HVY SS
HVY SS
Get something bigger...Later down the road you will regret it...I have 3 friends that ALL hate that setup. They aren't producing the power they should be and 2 are switching cams now, but I am unsure which one... Just my .02
