Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
New Racetronix fuel pump and new fuel tank installed but forgot the harness!!
Old Oct 17, 2011 | 09:24 AM
Rob94hawk's Avatar
My mechanic installed the new fuel tank and Racetronix fuel pump but forgot the harness!! Please God tell me that he doesn't need to drop the tank again to install it!!
So this is in:
But not this:
Old Oct 17, 2011 | 09:48 AM
pgerst's Avatar
Re: New Racetronix fuel pump and new fuel tank installed but forgot the harness!!
No, you do not need to drop the tank to install their harness. Also you can cut a door in the floor above the tank and make an access port to get to the pump. Just did it on mine (convertible) and it is way easier than dropping the the tank, there is a sticky about doing it.
Old Oct 17, 2011 | 10:51 AM
Rob94hawk's Avatar
Thanx. I was just told this. Was starting to panic. Just walked down to the shop and saw where it plugs in. But then again when it's up on a lift everything is easy to see.
Old Oct 17, 2011 | 02:45 PM
OBE1 95Z28's Avatar
You don't need to cut the access door to install the harness; I believe that pgerst thought you were asking how to install a new pump. The Racetronix harness connects to the pump cable that is external to the fuel tank. No need to drop the fuel tank.
Old Oct 17, 2011 | 09:41 PM
ItsRyan's Avatar
Let me know if this Racetronix system works any better for you.
Just curious
Old Oct 18, 2011 | 09:41 AM
pgerst's Avatar
I went from 11.3v to 12.2v at the pump with the harness; I think the pump output is more or less linear with voltage so equates to greater fuel delivery. Harness also has adapters to plug in a voltage booster if you need even more fuel (boost voltage even closer to 13.8.)
I also did their pump kit as well; I think the factory rating is 90lph (24gph), so in theory at 255 lph you can pump almost three times as much fuel with the Walbro but suspect the balance of the stock fuel system may limit that upper end.
Old Oct 18, 2011 | 04:32 PM
Pullngz's Avatar
I did mine quite some time ago, but I seem to remember, having to switch a wire out of one of the factory connectors.
Mike
Old Dec 21, 2011 | 02:15 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Would the Racetronix Wiring Harness work with a stock pump? Is there any reason someone shouldn't use their harness with a stock pump.
Old Dec 21, 2011 | 02:29 PM
OBE1 95Z28's Avatar
Their harness will work with a stock pump. If your not having a fuel pressure drop issue under load then there's no need for the harness and expense.
Old Dec 21, 2011 | 07:05 PM
BTC's Avatar
BTC
I already have their kit, but I also have a new stock pump. I was just curious whether their harness would present any issues when used with a stock pump. I've been told that it should work fine.
Old Dec 21, 2011 | 07:31 PM
Rob94hawk's Avatar
Forgot I posted this here as well as LS1tech. I was in serious panic mode at the time. lol
Old Dec 21, 2011 | 07:38 PM
BTC's Avatar
BTC
I may have hijacked your threads on both sites.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
