C5 wheels on a 95 z28 clearance issues.
Old Sep 26, 2011 | 08:33 PM
Kurt Crosbie's Avatar
After I out these wheels on I noticed the RR us rubbing against the chassis. Do I need to best in the chassis with a hammer to clearence it?
Sent from my VS910 4G using Tapatalk
Old Sep 26, 2011 | 09:19 PM
Str8boostin's Avatar
Re: C5 wheels on a 95 z28 clearance issues.
I had minor rubbing in the undercoating of my car with the rear tires, and extremely minor rubbing up front under the plastic fender/shields.
I'm currently using spacers but one of these days I'm going to take the wheel off and take a BFH and flatten the undercoating.
Where exactly are your tires rubbing?
Btw, I've got 265/40/17 (front) and 295/35/18 (rear) if it helps.
Old Sep 26, 2011 | 09:22 PM
Mine is rubbing on the front part of the RR fender shields. I believe mine are 275/40/18.
Sent from my SCH-I800 using Tapatalk
Old Sep 27, 2011 | 06:44 PM
So I beat the front of the inner fender well in on the RR with a hammer. Problem solved.
Old Sep 27, 2011 | 10:52 PM
If it was only rubbing on the right side, it may have been a problem of the chassis not being correctly centered over the rear axle assembly. That problem might have been solved with an adjustable panhard rod.
Old Sep 28, 2011 | 03:30 PM
mzgp5x's Avatar
I use an Adj pan bar to center 315-35-17 rears on 17x11 ZR1 wheels. Close clearance but no rubs after equal adjustment. I also clearanced the inner fender in the front area. B.
Old Sep 28, 2011 | 05:05 PM
Oh poop
Red 95 z28 M6 stock w/flows + c5's
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Jason Short
Jan 19, 2015 06:33 PM
rockync7
Jan 1, 2015 05:10 AM
ChrisFrez
Nov 30, 2014 08:41 AM
