Lowering Springs
Lowering Springs
I'm looking to lower my Z due to my new tires and Wheels combo. I put C-6 corvette wheels and tires on, and I have to much clearence between the top of my tires and the fender lip. Front fender I have over 2 1/2" and the rear has just over an 1 1/2" . I'm thinking about Eibach, one kit is 1.3" at the front and rear, and the other is 1.8 front and rear. Has anyone used either of these kits. Pro or sportline ? Any other thoughts on lowering springs besides Eibach ? Thanks for any suggestions
Re: Lowering Springs
The Eibachs Pro-kit for the 93-97 V8 F-body is your best choice with Eibach lowering springs (best spring rates, ride and handling ), but the rear spring have a tendency to sag and/or bend. Imo, Vogtland lowering spring offer better spring rates and don't sag, and lower around 1.2". You can also get them for under $200.
PM sent.
PM sent.
Yes, the stock gap is too large, but putting new wheels/tires should not have changed it.
I have c6 wheels on my 02 z28. They are 18" rims front and back. I just replaced the shocks/struts and put the eibac 1.2 lowering springs on yesterday. Car looks awsome but be careful if you have bigger wheels like mine. Everytime I hit a dip in the road my back tires bottom out against the wheel wells. Not sure if I am going to like it or not. My car had 110K plus mile on the stock equipment so ride is a lot better and the steering has tighned up, so I amn happy with that. I did also notice that it has killed my turn radius since the tires are now hitting the front wheel wells and pan handle bar quicker. I can live with that. This is my experince so just be careful with what you install.
Dec 1, 2014 08:08 AM
