Abs inop
Old Jun 8, 2011 | 03:13 PM
my1994z28's Avatar
Abs inop
This just happened today,I was driving along and I looked down to see that the ABS INOP light was on..I scanned it and it says that the brake is on?Any ideas on what could be wrong?I thought about deleting the ABS unit anyway because the car is never driven in the rain or snow,also it would free up a few pounds..
Old Jun 8, 2011 | 03:29 PM
Re: Abs inop
Do you mean the "BRAKE" light is on? If the e-brake is not on, that indicates a pressure imbalance between the front and rear braking hydraulics, due to a leak, air in system, master cylinder pressure problems, etc. That would explain why the EBCM turned off the ABS.
Moving to "Suspension, Chassis and Brakes".
Old Jun 8, 2011 | 09:35 PM
my1994z28's Avatar
Re: Abs inop
It lights up and says ABS INOP,I bled all four corners last night and it is still on,replaced the relay,and the 2 fuses for the ABS.I thought it was due to having air still in the brake lines,the brakes are definetly alot better.The light is still on.
Old Jun 8, 2011 | 09:51 PM
Re: Abs inop
What did you mean by this?
"I scanned it and it says that the brake is on?"
Is this based on an ABS code? My EBCM code list does not have a code that says "the brake is on".
There is a PCM code for "brake switch stuck on".
Old Jun 8, 2011 | 10:02 PM
my1994z28's Avatar
Re: Abs inop
I am unable to get the actual code number again,When I first scanned it PO@#$ showed up followed by "brake is on".....It is not throwing any more codes,but the ABS INOP is still on..I am going to try and clean the ABS sensor in the rear end tomorrow and see if that is the problem.
Old Jun 8, 2011 | 10:35 PM
Re: Abs inop
But what did you scan - the PCM or the ABS controller (EBCM)?
The brake light switch, on the pedal, is an input to both the PCM and the ABS. If the switch is stuck "on", that would probably cause the ABS to stop working.
Old Jun 8, 2011 | 11:11 PM
my1994z28's Avatar
Re: Abs inop
I scanned the PCM
Old Jun 9, 2011 | 05:15 AM
Re: Abs inop
Then check the switch.
Old Jun 9, 2011 | 05:36 AM
Guest47904's Avatar
Guest
Re: Abs inop
If the unit thought the switch was on all the time wouldn't the brake lights be on ?
Old Jun 9, 2011 | 04:59 PM
Re: Abs inop
I would agree, but he says he has a PCM code for the "brake stuck on", and since there is no code for that, I'm guessing it's for the "brake switch stuck on".
Old Jun 9, 2011 | 06:31 PM
Guest47904's Avatar
Guest
Re: Abs inop
Does he mean he actually saw a code 37 and it did NOT actually say to him "stuck on".
Do you suppose his third brake light is out and that's why he has an "ABS INOP" lit?
Or is to coincidental that the brake switch is on and the ABS INOP is on?????
The Action described for a 37 does NOT describe an ABS INOP light.
In the ABS section of the manual, it describes a DTC 94 for brake switch always closed. However the action taken for this is to NOT disable the ABS.
I think the young padawan is mistaken and very confused. Take it to someone with a good scanner and knows how to read it.
Old Jun 9, 2011 | 10:32 PM
my1994z28's Avatar
Re: Abs inop
I am 37 yrs old...I have a mac scanner,I dont remember the code number off hand,but it did say "brake is on"..my third brake light is working,now that you mention it,the ABS INOP came on when I installed my SS spoiler,the plugs matched up so I did not think anything of that until now.I did not have the time today to clean the ABS sensor on the rear end or check the brake switch out..I will do that for sure tomorrow and report back.
Old Jun 9, 2011 | 11:10 PM
Re: Abs inop
Correcting problems with the SS LED CHMSL, courtesy of Shoebox:
http://shbox.com/1/relay_for_ss_spoiler.jpg
That is most likely your problem.
Old Jun 10, 2011 | 08:54 AM
my1994z28's Avatar
Re: Abs inop
Thanks Fred,thats what I needed to see
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
