oil pickup screen tube size?
Old May 10, 2011 | 01:43 PM
Z28-50's Avatar
What size is the oil pump pickup screen tube on a stock oil pump for 1995 z28 LT1? 5/8 or 3/4?
Reason for asking I want to replace the pump with a melling 10554.
It appears the 10554 uses a 3/4 tube for the inlet.
Can I use the stock p/u tube with a melling 10544 pump?
Old May 10, 2011 | 02:03 PM
aaron_depue's Avatar
Re: oil pickup screen tube size?
Ive heard GM used both sizes on there pumps for a year or 2. I know if you go order a stock replacement oil pump at AutoZone the guy behind the counter will ask you "if you want the 3/4 or the 5/8 inlet?" My melling High Vol pump as well as the Melling Performance series High pressure pump (standard vol) both use 3/4.
Old May 10, 2011 | 02:07 PM
It should be 3/4". They changed during the 1994 model year.
Yes you can use the stock 3/4" pickup.
It really does not matter if you have a 5/8 now. I don't recommend you reuse a pickup, anyway.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Ws6Envy
Mar 3, 2015 04:31 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
Jul 4, 2005 05:00 PM
