Help with exhaust manifold
I have a pretty bad exhaust leak and I have now found where it is coming from. Its the last port on the passengers side closest to the firewall. Seems that the last 2 bolts on that side are loose. I was able to get a stubby wrench on the last bolt from the engine bay, it was loose but not to bad, tightened it down but the leak is still there. The next bolt, #5, 2nd to last one......how the hell do I get to this thing? I can get my fingers on it from above and it is loose, I can turn it with 2 fingers but I cant for the life of me get a wrench or a socket on it from above. I got under the car and I cant even see it......any advice? this leak is really getting to me, need to fix it. Any tips or tricks are appreciated. Thanks.
Re: Help with exhaust manifold
After having been that loose, the gasket is destroyed. Unless you replace the gasket, you are wasting your time.
A combination of flex joints, extensions and even a piece of hose can help get bolts out.
Chris Anderson
Jan 27, 2015 08:30 AM
