Right rear: Clunk/Squeak SOLVED
Old Apr 14, 2011 | 03:45 AM
IROCARMY's Avatar
97 Camaro with the following problem
- Squeak and metal contact sound in the right rear
- Did it when going over most bumps
- Hear inside and outside the car
- Can be hear when you push down on the rear of the car
- Sounded like its inside the rear quarter panel
I first sprayed parts of the rear suspension with oil (Sway bar busings, links)..no change
The problem was: Loose upper shock bolt, it was very loose and allowed the shock to hit/rub the body
Just lay down the back seat, pull up the carpet, pull out the plug and tighten the nut.
The whole time I thought it was someting like a failed shock
ZXXVIII
Sep 1, 2015 10:13 PM
TGGodfrey
Aug 17, 2015 08:43 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
WhiteZ95
May 11, 2015 08:52 PM
