E-brake not working
Old Mar 24, 2011 | 01:49 PM
Greg88's Avatar
E-brake not working
Ok, so my ebrake hasnt been working for a while, so i put it up on my hoist and noticed that one of the cables coming from the rear passenger side brake was broken off the divider. So i put it back on, no problems, and now there is still nothing with the handle? You can pull it up with no resistance, any ideas? Thanks for the help, Greg
Old Mar 27, 2011 | 10:33 PM
Greg88's Avatar
Re: E-brake not working
any body have any ideas? Thanks.
Old Mar 27, 2011 | 11:43 PM
Larsv8's Avatar
Theres an intermediate wire that wraps around the parking brake assemby, goes through the floarboard, and connects to another wire.
You need to find out if that is the wire to replace or the one that it connects too which leads to the wheel.
Old Mar 31, 2011 | 07:46 AM
Greg88's Avatar
so goes threw the console? Alright, i'll check that out.
Old Apr 6, 2011 | 02:32 PM
Greg88's Avatar
turns out everything is ok from the lever to the brakes. Nothing is seized or loose. its all tight. Is there something that im missing on the brakes? It worked totaly fine then once day it just stopped? any ideas?
Old Apr 6, 2011 | 06:01 PM
pgerst's Avatar
Sounds to me like one of the cables is broken inside the sheath; midway between the tranny and diff above the drive shaft is the yoke and you can pull on each cable end and see if they are still solid. There also is a e-brake travel adjustment http://shbox.com/1/adjparkingbrake.jpg
Old Apr 7, 2011 | 04:59 PM
Greg88's Avatar
Yea i pulled on both cables and they are both tight? I dont understand why all of a sudden it stopped? Maybe i should just adjust it and see i guess. hopefully not smoke out the rear brakes.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
