stock sway bar sizes
Old Mar 6, 2011 | 01:11 PM
1badasZ's Avatar
bout to order some more sway bar bushings and need to kwow what the stock sizes are. also do most that drag race remove the front one or leave it on. it wont be a all out race car just street/strip. thanks
Old Mar 7, 2011 | 05:14 AM
NJ-LE's Avatar
Re: stock sway bar sizes
1badasZ:
I forgot to document the website address! The page I captured was titled:
"4th_gen_suspension.htm#ch4_5a" and had the following info:
4th Generation (1993 - 1997)
Q: What are the specs on the stock sway bars and springs?
A: The V6 models have a 30mm front sway bar and a 17mm rear sway bar. The spring rates are 223 pounds per inch in the front and 95.4 pounds per inch in the rear.
The regular V8s have a 30mm front sway bar (same as V-6 model) and a 19mm rear sway bar. The springs are 292 pounds per inch up front and 114 pounds per inch in the rear. The 1LE and WS6 suspension package has a 32mm front sway bar and 19mm rear sway bar (note, 1993 and early 1994 1LEs got a 21 mm rear bar). The springs are 360 pounds per inch up front and 130-180 pounds per inch (progressive) in the rear (note, 1993 1LEs got the same springs as regular V8s)."
F'n1996Z28SS
Aug 23, 2023 11:19 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
