Rotor rubbing rearend caliper
Old Feb 1, 2011 | 10:59 PM
YoungCompton's Avatar
I have been getting this loud squeak (EEEEEEeeeeeeeeee) when I make hard turns or turns that I have to hold (freeway on-ramps). I have been driving like this for X amount of years now and i am finally tired. I have read that C-Clips and washers can fix this problem. I plan on switching both of my axles to Moser's, and 3.73s, and of course new c-clamps. Just thought I would share some pictures.
Old Feb 2, 2011 | 06:03 AM
Re: Rotor rubbing rearend caliper
Is the caliper rubbing on the rotor, or is it the brake pad rubbing on the unmachined portion of the rotor? Almost looks like the rotor surface should have been cut a 1/4" wider.
Old Feb 2, 2011 | 11:46 AM
I can't say 100%, but I think the rotor is rubbing on the caliper. If u look closely at pictures 3 and 4 you can see little peices of metal on the inside of the caliper facing the rotor
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
colts0455
13
Aug 7, 2015 09:15 PM
force10
Jul 30, 2015 04:56 PM
