Shocks/Springs
Old Jan 16, 2011 | 01:57 PM
Josio0323's Avatar
Shocks/Springs
You know how in a new car it rides smooth? and bounces smoothly when you go on a hole
My camaro does not do that. It just clunks hard when i go over a speed bump and the rear right goes so low it scrapes on the metal panel
I have 18' rims what needs to be replaced to get it to run smooth and bouncy
I plan on rebuilding the car since the blown head gasket
Old Jan 16, 2011 | 03:26 PM
bluz28's Avatar
Re: Shocks/Springs
First, set you tire pressure around 30-32 psi max, any higher give a harsher ride. Second, replace the rear bump-stops if they appear damaged or excessively worn. Third, replace the exhaust hanger rubber bushings if the hangers fit loosely in them. Forth, check the front upper and rear upper shock shaft mount nuts and tighten them if loose. Or replace the shocks if their old/worn-out with a set of Bilstein shocks.
Old Jan 16, 2011 | 03:43 PM
Josio0323's Avatar
Re: Shocks/Springs
bout to jump on in a few ill let ya know... ima go to autozone to see if i can find the parts there i know the rear right is failign so ima just buy rear shocks and replace
Old Jan 16, 2011 | 05:56 PM
Re: Shocks/Springs
We have a forum for "Suspension, Chassis and Brakes". I'll move your post there.
You also need to modify your "Signature" with more info about your car - year, model, engine, trans and any major mods. We can guess from your limited description that its a 4th Gen V6, since that's when the Cayenne color was available.... but why make people guess when they are trying to help you?
You aren't going to find quality shocks at Auto Zone.
Shon Herron
Oct 7, 2011 11:58 AM
car_ramrod
Parts Wanted
Apr 25, 2008 07:47 AM
Shon Herron
Mar 18, 2007 02:22 PM
DarkHorse
Jan 30, 2007 05:42 PM
ChrisUlrich
13
Mar 5, 2006 12:20 AM
