Hurst line lock instal
I bought a Hurst line lock kit with pre bent lines from thunderracing for my 1996 Trans Am A4. Does anyone have a write up with pictures on how to install it? I have already searched and had no luck, Thanks.
Re: Hurst line lock instal
The line lock solenoid goes in the line for the front brakes, running from the back connection on the master cylinder to the switch block on the side of the ABS motor. Rear connection on the master to the solenoid. Solenoid to the switch block.
Did you get the complete kit with the relay?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
