Bmr suspension? gains?
I just bought bmr rear adj. LCA's, adj. panhard bar, adj. torque arm and adj. front upper control arms. Also have lower control arms and bmr k-member and 4 qa1 coilovers.......now my best run with the car so far was a 13.00 @ 113 mph with a 1.99 60' with all stock suspension and radials. Now my question is what kind of gain should I expect with all the new bmr stuff and m/t drag radials in the rear and front runners in the front?
Re: Bmr suspension? gains?
I pull a consistent 1.6x 60' on a full weight TA with BMR drop springs, non adjustable LCAs, adjustable panhard rod, bilstein shocks with a set of Mickey Thompson DRs. I've been told a tenth off the 60' is worth 1.5 at the end of the 1/4, so you may be able to see some pretty good gains with suspension work.
