Priming oil Pump. Something is not right
I'm using a drill to prime my freshly rebuilt engine and something does not seem right. My rockers are not filling up with oil and flowing out the tip
When I remove the rockers and pushrods the lifter is flowing lots of oil. Then I put the pushrods on the lifter and there is flow oil out the top of the pushrod. But when I put the rocker on not very much oil is coming out the top of the rocker. Oil is coming out and down the rocker stud but not out the top of the rocker like I have saw on my last engine.
I'm using
cc 1105 http://www.summitracing.com/parts/CCA-1105-16/
http://www.summitracing.com/parts/CCA-7955-16/
with LS7 lifters.
Is this normal or do I have a problem.
I'm using
with LS7 lifters.
Sandersen511
Jan 13, 2015 03:49 PM
