Melrose T-Top Valve Covers w/ Stud Girdles and Comp Pro Mag's
Old Jun 1, 2010 | 08:49 AM
Schweet97Z's Avatar
-Comp Pro Magnum full roller rockers. 7/16" NSA. You can use up to a 1.550 dia spring with the pockets that are cut in them. These are made from chromoly steel!
-Comp cams rocker arm adjusting nut with poly locks, .750 OD, ~2.5" tall for use with stud girdle.
-Aluminum stud girdle, The girdle is drilled and tapped for holding down the valve cover with supplied studs! This is a custom setup from Melrose T-top
-Custom modified cast aluminum valve covers from Melrose T-top. I just had these powdercoated. They are extra tall and made to work with the girdle studs for hold down. The one cover has been modified a bit. It was notched and welded to allow for alternator clearance. NO ALTENATOR RELOCATION NEEDED The modification is very subtle and if you weren't looking for it you wouldn't even see it.
The rockers are used but have alittle over 1000 miles total on them. They are in brand new condition! I paid alot of money for this setup. This is just about the best valvetrain set up you can buy without going to shaft mounted rockers.
500 Shipped FIRM! This is my bottom dollar price. So please don't PM me unless your ready to buy a badass setup.
PICS
Old Jun 1, 2010 | 12:19 PM
charliediss's Avatar
Are the rocker arms 1.6?
Old Jun 2, 2010 | 10:36 AM
Schweet97Z's Avatar
Yes they are.
Old Jun 2, 2010 | 01:24 PM
Originally Posted by Schweet97Z
Yes they are.
I cant see pics, would you mind sending them to charlie_diss@yahoo.com? I am very interested. Thanks,
Charlie
Old Jun 2, 2010 | 04:28 PM
Schweet97Z's Avatar
pictures sent.
Old Jun 3, 2010 | 09:06 AM
Schweet97Z's Avatar
Bump!
Old Jun 6, 2010 | 12:38 PM
Schweet97Z's Avatar
STILL FOR SALE!
Old Jun 9, 2010 | 11:31 AM
Schweet97Z's Avatar
Willing to trade for guns, 4 wheeler parts (Specifically Yamhaha Banshee), tools, and anything else that you think might spark ones interest. Need these gone. Have no use for them anymore.
Old Jun 9, 2010 | 11:51 AM
Projectz28's Avatar
Moderator
Harold sorry to see them go but you are right they are the best bang for the buck without going shaft mount.
For anyone intrested this covers/rocker set up is bad azz! I know because they used to be mine before I went to a shaft mount rocker. You will not be dissapointed and you will have a set up that you can not buy anywhere for this price! Harold is good to deal with and these are great rockers and covers! This is a steal at this price!
Old Jun 10, 2010 | 06:30 AM
Schweet97Z's Avatar
Thanks for the Bump Brian.
Old Jun 11, 2010 | 01:41 PM
Schweet97Z's Avatar
Sold
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Roadie
Feb 16, 2015 10:34 AM
Jul 4, 2005 05:00 PM
