1995 CPT PRO-RACE Rebuilt 4L60E
Old May 12, 2010 | 08:19 PM
TransAm-Z's Avatar
(SOLD)
1995 CPT PRO RACE REBUILD 4L60E.
Transmission was built in 2008 by CPT (Frank Cahall) and has about 3000 miles on it. Shifts hard! Great transmission! For more info go to http://www.cahallperformancetransmissions.com/ I am selling this setup to fund another car project. This Transmission is still in my 95 TransAm if anyone is interested seeing it run before they buy.
Transmission includes everything listed below in the Pro-Race-Build!
PERFORMANCE REBUILD: Custom shift kit, "Corvette" 2-4 servo, .500" Sonnax pressure regulator boost valve, Raybestos "High Energy" 2-4 band, 6 Borg-Warner 3-4 frictions, Sonnax "High RPM" pump slide spring, New Borg-Warner 29 element input sprag
RACE REBUILD: Custom shift kit, Fairbanks "Billet" 2nd servo, Sonnax "Super Hold" 4th servo, .490" Sonnax pressure regulator boost valve, Alto "Wide" Red Lined 2-4 band, 7 Raybestos "Blue" 3-4 frictions, "Kolene" friction coated 3-4 steels OR Raybestos "Z-Pack", Sonnax "High RPM" pump slide spring, "The Beast" H/D sun shell, New Borg-Warner 29 element input sprag, Sonnax "full throttle upshift sleeve" (700)
PRO RACE REBUILD: Everything in the Race Rebuild + the addition of the 4L65E front support, 4L65E hardened output shaft, and updated steel piston set for the input drum. Recommended for car's hitting sub 1.7 60' times
$1200 (SOLD!)
Fuddle 3200 2.1 Stall Converter (Lock-up Converter) (SOLD)
LS1 Aluminum Drive Shaft $125
Old May 13, 2010 | 08:23 AM
RROADCAP's Avatar
Where u located-interested in the trans. I have one of franks transmissions now and it's working great
Old May 13, 2010 | 11:13 AM
TransAm-Z's Avatar
Tipp City, OHIO 45371 (Close to Dayton)
Old May 13, 2010 | 11:30 AM
swasenko's Avatar
tranny
I am pretty interested in the 4l60e. Email me at swasenko@hotmail.com.
Old May 15, 2010 | 12:56 PM
TransAm-Z's Avatar
Weekend Bump!
Old May 18, 2010 | 05:48 PM
TransAm-Z's Avatar
Still available... Make an offer!
War Engine
Aug 21, 2015 05:28 AM
dkred94z
Aug 20, 2015 03:09 PM
canuck94z28
Aug 19, 2015 05:50 PM
Trimix
Parts Wanted
Aug 15, 2015 10:46 AM
Bz8
Jul 13, 2015 04:46 PM
