Stock Tires
Old May 8, 2010 | 07:52 AM
Mays1975's Avatar
Stock Tires
My 1996 Z28 LT1 have oversized tires they stick out about 3 inches from the fenders. Does anyone know what the stock size tire would be for my car?
Old May 8, 2010 | 11:21 AM
If the tires are sticking out 3" past the edges of the fender, the problem is most likely the wrong wheels, not the wrong tire. The stock wheels (16 x 8.0" 55mm offset) place the tire at least 1" inside the fender, so for an oversize tire to stick 3" outside the fender with a stock wheel is impossible. Sounds like someone put the wrong wheels on it, probably with "0" offest, rather than the required 55mm (2.2") offset.
Stock tire on a 96 Z28 was either 235/55-16 (base V8) or 245/50-16 (RPO QLC - Z-rated tires supplied with performance rear axle ratio).
Old May 8, 2010 | 12:56 PM
Mays1975's Avatar
Thank you very much. This site rocks. Everyone on here has been VERY helpful
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Ken Cemo
Feb 13, 2015 08:37 AM
Ken Cemo
Jan 27, 2015 08:45 AM
Jason Short
Jan 19, 2015 06:33 PM
