inner wheel brake crud. best stuff to remove it?
Old Mar 4, 2010 | 04:51 PM
Caps94ZODG's Avatar
Ok got some rims that I am putting on the car and want the rims to be clean on the inside too. Just wanted to see what the best stuff or the best luck someone had with a cleaning product out there to get the job done so they are back to like new.
Its all that brownish brake dust in the inner wheel. suggestions?
I am doing this in the house. So I do not have access to a pressure washer or anything high pressure or stuff like that or hose.
Old Mar 8, 2010 | 09:37 PM
Chevyssoccer's Avatar
Well, if you can get them clean I found that spray on wax helps keep them clean longer.
Old Mar 9, 2010 | 10:50 AM
Caps94ZODG's Avatar
Update:
simple..I used a magic eraser..well 3 actually. But just some water and that and it came right off. Then had some NuFinish lying around and coated the inner wheel with that and wiped it off.
DirtyDaveW
Dec 1, 2016 05:37 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
