Will IROC rims fit my 95 z28 convertible?
Hi All....
Just a quick question. I have the factory rims and tires on my 95 convertible z28 245/50/16's and I nee a set of used tires to get me through this season. I found some used P245/50/R16 96H, DUNLOP SP SPORT A2 for sale but they are on FACTORY CAMARO IROC-Z MAG WHEELS. Will this bolt pattern and size fit my 95?
Cheers... Rob
Cheers... Rob
The bolt pattern is the same ( 5 x 4.75" ), but the offset of the wheels is different. The 16x8 IROC wheels have a 0 offset in the front, and a 16mm offset in the back. By comparison, the 4th Gen 16x8 wheels have a 55mm offset.
As a result, the 0mm IROC's will stick out about 2.2" more than your 4th Gen wheels, and the 16mm IROC's will stick out about 1.5" more. You will just have to decide if you will be OK with the wheels pushed out that far toward the outside of the fenders.
