Will 10.5" Wide x 18" with 50MM Offset fit in FRONT? 4th Gen LT1.
Anyone know if an 18x10.5" will work up front on a LT1 car?
I found a set of (4) all black Z06 rims locally but all four are 10.5" wide. I would likely run something like a 315/30/18 rear and 275/35/18 front if I get these.
Hoping a 10.5" wide wheel will clear from rubbing in the front on a 4th Gen. with reasonable size tires.
* READ the sticky at top already. Could not see if those wheels would NOT fit up front or not *
Thanks,
Joe
Thanks,
Joe
Thanks buddy ...
Did some math - from your mounting surface to edge of rim should be 195.7 MM and these should only stick in the wheel well 191.35MM
So technically, I should be able to run these. Will be using a narrower tire up front than you. As long as its not taller I am good
What size spacer would you estimate will be needed to use on stock brakes?
for some reason I want to say it's a 1/4 that needed, but I don't remember for sure, it's been awhile since I checked. My advice would be to get the wheel and put it on and then measure for a spacer that'll put it right where you want it.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Dec 4, 2014 11:56 AM
