2010 Camaro Wheels Fit on 93-02??
Old Feb 6, 2010 | 09:27 AM
Toby Gallicchio's Avatar
Does anyone have pic's or know if the 2010 rims off the new Camaro's will fit on older models??? Im redoing another 95Z and would like to see em on the car before i buy. Thanks for any help!!!
Old Feb 6, 2010 | 10:59 AM
NewbieWar's Avatar
doubt it, new camaro has staggered 19/20's doesnt it?
or 20/21's I forget, I know the concept had 22/22
Old Feb 6, 2010 | 12:08 PM
Whether the wheels "fit" has nothing to do with the diameter of the wheels, or the fact that they are "staggered".
The first problem is the 5th Gens have a 120mm biolt pattern, and the 4th Gens use a 120.65" (4.75") bolt pattern. Whether its a good idea to use the 120mm bolt pattern on the 4th Gen has been discussed extensively. Some people claim they have run 120mm wheels (BMW for example) with no problems, others have cited problems with the lug nuts coming loose and the studs breaking.
The next issue is the offset of the wheels. You need to check the offset of the various 5th Gen wheel sizes (18", 19", 20") and compare it with the guidelines in the FAQ for the 4th Gen.
Old Feb 6, 2010 | 04:02 PM
Thanks for the help!! I was really hoping they would work but the more im looking into it, i dont think it's going to.
Old Feb 6, 2010 | 06:19 PM
The widest stock wheels for the 5th Gen are only 9.0" wide. That really limits your tire selection.
Old Jul 30, 2011 | 11:12 PM
temekeoz28's Avatar
Re: 2010 Camaro Wheels Fit on 93-02??
it will fit ....they fit on my 96 z28
Old Jul 31, 2011 | 09:28 AM
Physically, they fit. With regard to the bolt pattern, they don't.
Old Aug 1, 2011 | 04:37 PM
wu6fiend's Avatar
No offence, but that looks totally ridiculous on the 4th Gen. 18" max. Anything larger belongs in the 'hood with the gangstas.
Old Aug 7, 2011 | 01:39 PM
MustangEater82's Avatar
Do the v6s run 19s and 20s?
Old Aug 7, 2011 | 03:16 PM
http://www.camaro5.com/forums/wiki.p...WHEELS___TIRES
Old Aug 7, 2011 | 09:21 PM
stan1971's Avatar
in my honest opinion 20 inch wheels look so ugly on a 93-02 Camaros....it makes it look jacked up front and back and just looks cheap , might as well put a double spoiler on the back.......17's are perfect on those cars..maybe 18's at most.
Old Oct 16, 2011 | 07:33 PM
Strike8Fifty's Avatar
Old Oct 17, 2011 | 10:27 AM
Tokuzumi's Avatar
^ Why does the rear quarter panel look like the car has been wrecked? And holy ground clearance, Batman!!!
Old Oct 18, 2011 | 05:22 AM
Looks like the rear fender sheet metal has been bowed out to clear the tires. I guess not everyone has the same definition of the word "fit".
Old Oct 19, 2011 | 02:48 AM
rear panel was done by choice not to fit those
