Excessive idle problem after radiator hose burst
My camaro's upper radiator hose burst the other day so I replaced it. Problem is that now the car idles around 1700 rpm. This did not happen until the hose burst and that doesn't make sense to me. The car is a 5 speed and does have the air pump still intact. When the hose burst, it leaked down onto the air pump and that's when the problem started. I checked and replaced the IAC and that did not help the situation. The car still idles around 1700 rpm and I hear what sounds like an air leak from the driver side of the engine, but I can't find any vacuum leaks. As far as I know the air pump is still working because when I pulled the hose off it was still sucking air from the air intake. Did the water possibly damage the air pump, causing it to make the car idle high?
Yeah I reset the computer and the car still idles very high. I pulled the fuse for the air pump and that did not change anything so I must have a vacuum leak somewhere. Problem is that I can't find it
ro2207
Dec 4, 2014 06:18 PM
