Temp gauge staying at 3/4 and fans always on
Yesterday as I was driving home on the highway I noticed my temp gauge was staying up at 3/4 high. (approx 115 Celcius).
Once I turned down my music I could faintly hear the fans constantly running on high. But car was not overheating. Just running close to the overheating point.
When I got off the highway and shut it off the fans ran on high for another few minutes cooling off the engine. Once the fans shut off, and there was no more cooling the coolant was boiling in the rad (could hear and feel it with hand on rad cap).
I think it was hissing a touch from the rad cap area. Was hard to tell with traffic noise.
Anyhow, just wondering if you guys have any suggestions? I'm thinking loss of pressure due to faulty rad cap. Either that or thermostat is stuck closed. However, I'm not sure if the car would stay out of the red line if the thermostat was toast. I'm gonna go out and look for any obstructions on the rad. TIA
Ryan
Ryan
Yup. Rad is full. Overflow bucket is right where it should be on the cool mark.
Something to mention is that I did change the low coolant sensor a few months back and it was sending false readings (light would come on intermittently when coolant level was fine).
However, I filled the rad back up afterwards and open the bleeder valves and ran it until the air bubbles stopped and coolant came out. Plus the fact its been running fine for the last few months. So I doubt it could be that.
Any other thoughts?
Any other thoughts?
Check the thermostat to see if it failed half way open. I've had one do that with me with the same results your seeing (It would run warm but not hot), but , It was not on a LT1 which has a different cooling system. Still it might be worth a check.
Hope it helps. LF
Hope it helps. LF
just a thought, when i bled my system with engine running it didnt bleed correctly and it took a while for it to show (i guess maybe the air bubble took a while to move to the thermostat) anyway i bled it real good with engine off, actually pushing down vertically on the hose with the bleeder and tightening the bleeder with hose pushed down, got quite a bit more air out. Give that a try....you probably have an air bubble stuck in there.
Bubba4: was thinking of switching the stat tomorrow. thanks for the suggestion
9sevenZ: i ran the car with the bleeders open yesterday for awhile, and didn't even get the slightest bit of air.....wouldn't really think it would still be air several months (or more) after the fact that i topped up the system tho.
plus the fact that all i did was top up the rad when i changed the sensor. only had to drain it about 1/3. not like it was a full system fluid exchange...
Injuneer: air dam is still there. checked for obstructions on the rad: absolutely nothing. and no, it happens even when idling.
thinking i might try the rad cap tomorrow. dealership parts dept. not open today.
I had a rad cap go bad on one of my previous Zs, and there was such pressure loss that it actually overheated on me....
I'll let you guys know how i make out. any more suggestions welcome of course. thanks.
sorry for not updating sooner...but anyways, i changed the rad cap and no go. still running hot. so then changed the stat, and that did the trick.
thanks for the help guys.
Magenta_Hearts
Mar 29, 2017 08:54 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ro2207
Dec 4, 2014 06:18 PM
