91 3.1L Starts and dies!
Old Sep 11, 2009 | 11:07 PM
Seabat's Avatar
91 3.1 v6 starts briefly and dies. If you try to start again, nothing. If you turn off ignition and try again it starts briefly and dies. Put some gas directly into the throttle body and it tried to run, backfired and started a small but exciting fire.
Fuel pressure is 40 psi, spark from coil is good. Has a code of 35, IAT sensor circuit fault. Will the IAT sensor fault keep it from running?
The manual I have access to isn't worth sour owl squat, trying to fix this for a friend and my ignorance is starting to show. Any help would be greatly appreciated.
93Z M6 RED
B&M Shifter
egr, tbb, cutout.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
Ricardo
Nov 29, 2014 10:58 AM
