FS: 94z28 6 spd. forged 358. $5000
Hello. Well, had to take advantage of the first time home buyers tax credit...so I'd like to sell the car. (WORKING ON PICS AS WE SPEAK)
94 z28. black exterior. grey and black two tone cloth interior. 6 spd car. car has 96,000 original miles.
Rebuilt the engine 2 years ago...about 5-6,000 miles on it since rebuild
-358cid. diamond forged pistons. 11:1 compression
-gm perf. parts forged crank (3.48)
-arp studs throughout
-Scat 4340 I beam rods
-stock heads with bowls ported. manley 1.94/1.50 stainless valves. comp cams beehive springs with titanium retainers.
-bret bauer designed comp cams .603/.600 lift 230/236 @.050 109lsa. sounds very aggressive, but actually a copy of a design bret made for a road racer so it makes power everywhere. very streetable, I have been driving it daily this summer.
-pace setter ceramic long tubes
-hooker catback
-bbk 52mm tb
-ford 30# injectors
-meziere electric water pump
-K&N intake with 1LE elbow.
-ATI superdamper on the crank
-6 speed rebuilt about 3 years ago due to a synchro going out. carbon fiber backed synchros put in and new seals.
-clutch replaced this spring. clutchnet 6 puck sprung hub setup.
-stock 10 bolt, but with 3.73 gears and "T/A" brand stud girdle kit and aluminum cover
suspension is all stock, minus poly end links i put on this year.
also has UMI weld on subframe connectors.
has 17x9 wheels from '00 SS with brand new sumitomo htrz 2 tires.
Interior is very clean with no rips or tears...very minimal sund damage (garage kept all of its life). Paint is pretty good for a 94. shines up very nice, but has typical spider cracks on the nose and random scratches from over the years. t- tops do not leak at all. car drives great. Made 363rwhp and 355rwtq on stock heads through a hooker catback on a mediocre tune 3 or 4 years ago. I do have some receipts i can show on the engine internals.
working on pics as we s peak...so i'll post some later tonight. must have $5,000 thanks! 574-304-4374
-hooker catback
-bbk 52mm tb
-ford 30# injectors
pics as well!! robpete22s@yahoo.com
Cbr02
Aug 24, 2015 07:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
