1994 camaro z28
Old Aug 15, 2009 | 04:41 PM
didntdoit's Avatar
1994 camaro z28
For sale a street,race, and show car . Car is apraised at $ 50,000 have all reciepts. This car is a one of a kind .
WILL CONSIDER TRADE FOR 2000 - 2004 CORVETTE WITH LOW MILES
Email me if you have any qustions or would like to see PICS
didntdoit11@comcast.net
.......................SERIOUS INQUIRIES ONLY PLEASE..................
....................... $28000 obo.....................
http://s170.photobucket.com/albums/u259/didntdoit11/
vids are from 07-08 none from this year,took car out 2 times consistant 10.60(new nitrous setup) needs to be tweeked car should run high 9's
cant post pics
383 Racer LT1 Short Block
ET Performance Ported LT1 Heads
ET Performance Port Matched Intake Manifold
Felpro Head Gaskets
Cloyes Timing Set
VRE Specked Comp Cams Camshaft
ARP Head Studs
Trend Chrome Moly Pushrods
CSI Water Pump
Precision Vigilante 3200 Stall Converter
Bosch 42.5# Fuel Injectors
Morel Hydraulic Link Bar Lifters
A1000 Aeromotive Fuel Pump
Holly Blue Nitrous Fuel Pump
Spohn #741 Tubular Lower A Arms
Spohn #742 Tubular Upper A Arms
PA Racing Tubular K-Member
Pacesetter Long Tube Coated Headers
Pacesetter Off-Road Y-Pipe
BBK 58mm Throttle Body
Moroso Stroker Oil Pan
ATI Dampner
Felpro Valve Cover Gaskets
Header Gaskets
Comp Pro Magnum 1.6 Ratio Roller Rockers
Canton Fabricated LT1 Valve Covers
MSD Universal Wiring Harness
MSD 6al Ignition Box
MSD Blaster 2 Coil
Autometer 5” Tachometer with Shift Light
Autometer Oil Pressure Gauge
Autometer Fule Pressure Guage
Energy Suspension Poly Motor Mount
Energy Suspension Poly Transmission Mount
Aeromotive Fuel Pressure Regulator
Hal 325# Front Springs
Hal Adjustable Front Shocks
Gm Guide Plates
Comp Cams Rocker Studs
Moser 12 Bolt Rear End
Spohn Adjustable Spherical Rod End Pan Hard
Spohn Rear Sway Bar 1mm
Th400 reverse manual valve body
Old Aug 20, 2009 | 09:30 PM
didntdoit's Avatar
bump
Old Oct 22, 2009 | 03:28 PM
didntdoit's Avatar
one more bump
Scottylt1
Jan 8, 2015 02:48 PM
NewsBot
Dec 28, 2014 06:20 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
