5th gen wheels on 4th gen???
Old Jul 30, 2009 | 12:44 PM
bowtiepwr's Avatar
>I wonder what will look like???
I bet it looks good... anyone know if there are aftermarket replicas wheels avail yet?
Old Jul 30, 2009 | 03:53 PM
reamo04's Avatar
ebay has some
Old Jul 31, 2009 | 06:31 PM
BandDirector Blk98ZM6's Avatar
Just curious, what are the 5th gen wheel sizes, bolt pattern, and offset?
Old Jul 31, 2009 | 08:19 PM
I found this info on an auto review website:
Wheels/Tires
LS:
18 x 7.5-inch steel
P245/55R18 all-season
LT:
18 x 7.5-inch aluminum
19 x 8-inch aluminum
P245/50R19 all-season
SS:
20 x 8-inch aluminum (front)
P245/45ZR20 summer (front)
20 x 9-inch aluminum (rear)
P275/40ZR20 summer (rear)
There is a post on the 5th Gen Wheels and Tires forum that indicates the bolt pattern is 5 x 120mm.
Old Aug 1, 2009 | 03:00 PM
bowtiepwr's Avatar
Originally Posted by Injuneer
SS:
>so will the 120mm fit our 4th gen F bods? (not to sure about the 120mm compared to 5 x 4 3/4).
Old Aug 1, 2009 | 04:25 PM
n2ceptor's Avatar
120mm = 4.72" ?????
Old Aug 1, 2009 | 07:31 PM
bowtiepwr's Avatar
Originally Posted by n2ceptor
120mm = 4.72" ?????
>ahhh so they will not fit.
Old Aug 1, 2009 | 08:34 PM
This is a long standing debate. People have but BMW (and other 120mm bolt circle) wheels on 4th Gens (120.65mm bolt circle), and some claim they have no problems with them. Others have mentioned broken studs and the lugs coming loose. Sort of up to you to decide if you want to take a chance.
Old Aug 3, 2009 | 03:54 AM
bowtiepwr's Avatar
>I wonder if they had to "machine" the wheel stud holes out and use larger tapered lug nuts???
Old Aug 3, 2009 | 09:12 AM
The people who are installing the BMW wheels don't do anything. They just bolt them on. 0.65mm = 0.0256". Its a very small difference.
Bolting the wheels on will cause the studs to bend inward slightly, until the cone on the lug nut wears the hole off center. Or, the first lug nut will "center" the wheel incorrectly, and the other 4 studs will be bent to accomodate the wheel being slightly off center. The studs aren't designed for bending stress, they are designed for shear stress. Combine bending stress with shear stress and you may overstress the studs.
Old Aug 3, 2009 | 08:58 PM
bowtiepwr's Avatar
Old Aug 4, 2009 | 07:36 PM
350350's Avatar
I wonder if anyone has thought of making a drill-bit tipped lugnut yet, like a self-tapping screw?
In the olden days, people used to also redrill their axle hubs for different bolt circles... So in other words you ended up with 2 sets of bolt holes 'clocked' as far apart as possible, kinda like a unilug wheel but on the axle side isntead... Cheap and easy if you had the patience to be sure you got the bolt circle centered. Not sure you could do this with fronts but for rears it might work?
But seriously though, the safety issue aside, I'd like to see what the 19x8's would look like on a 4th gen...
Old Aug 4, 2009 | 07:46 PM
350350's Avatar
You know, the more I think about it, 4th-gen front hubs are stand-alone, right? You could drill a second bolt circle into a 'spare' set of hubs, right?
Old Aug 4, 2009 | 07:54 PM
350350's Avatar
Like this with a 2nd bolt pattern drilled into it:
http://cgi.ebay.com/ebaymotors/93-94...Q5fAccessories
Old Aug 5, 2009 | 12:23 AM
zero231's Avatar
I don't know about the 5th gen wheels, but I have heard the guys that use the bmw wheels on their f-bodies the right way use 'eccentric' lugnuts that swivel around a bit to center the wheel correctly...
