WTT 88 LX mustang for LS1 or DD
Old Jul 17, 2009 | 02:47 PM
95TAMaddog's Avatar
1988 LX Mustang. Black with Red Interior.
This car is very streetable. It's a pump gas 306, The engine has a Saleen intake, 24# injectors, Cobra mass air meter, 70mm BBK throttle body, Eldebrock Aluminum Performer 5.0 heads with light amount of port work, Lock wire head gaskets, Roller rockers, Lunati Hydraulic roller camshaft 230/240 @.05 with around .520 lift,Light weight TRW pistons, Stock block, Crank and rods, Mac long tube headers. NOS dry kit. Can get around 15mpg if taken it easy on it.
Trans: Tremec 3550, Lakewood bellhousing, Spec Aluminum flywheel, Spec stage 3 clutch, Hpm Cross member, Aluminum drive shaft.
Rear Axle: 8.8 with 31 spline Moser axles, 31 spline limited slip, 3.73 ring and pinion.
Suspension:Front- UPR tubular K-member, UPR tubular A-arms, UPR caster camber plates, UPR coil over kit, Lakewood 90/10 struts.QA1 coil springs.
Suspension:Rear- Hpm Mega bite JR. lower control arms, Eldebrock double adjustable uper control arms, Lakewood rear shocks, Hpm sub frame connectors, CCM Fabricated 3/16" steel Torque boxes.
This car has much more , I have over $13,000 invested.
$7000 OBO
Hughey Bellue
Old Jul 26, 2009 | 08:20 PM
95TAMaddog's Avatar
to the top
Old Jul 30, 2009 | 12:03 PM
95TAMaddog's Avatar
to the top
Old Aug 6, 2009 | 07:38 AM
95TAMaddog's Avatar
Car has sold.
Hughey
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
