1994 camaro rolling chassis
Old Jun 25, 2009 | 11:21 AM
swasenko's Avatar
This is a 1994 Camaro Z28 with T-tops. It is Patriot Red. I rebuilt this car from front to back for it to be a full blown race car. After I put a new rear end in it I took it up to have an alignment done and the shop smacked the oil pan into the hoist and knocked the pickup off. After running it dry they blew the motor. I still have some engine components, but not all. It would be pretty cheap to buy a pulled LS2 out of a wrecked chevy and drop it in. Right now it's being sold as a rolling chassis. The stuff in Italics is not included. I can deliver this to someone within a 500 mile radius for $1.50 a mile. You can call my cell at 313-980-1428 with any questions.
Eagle 383 stroker kit
- reverse domed pistons
- forged crank
- file fit rings
Lunati timing set
High flow water pump
Ported LT4 intake
AFR CNC competition ported 195cc, 75cc combustion chamber heads
Moroso polished valve covers
Cam Motion
LT4 rockers and springs
Custom flywheel
March under drive pulleys
MSD 6-BTM ignition, coil, distributor, and 8.5mm wires
Optima deep cycle red top battery
Twin radiator fans
BBK 58mm throttle body
Vortec intake elbow
Ported MAF sensor
K & N cold air intake
New PCM
Turbo 400 trans
stall converter, 2800 stall
Custom build 3 in. aluminum drive shaft
1350 yoke
Moser 12 bolt with 373 gears
Adjustable custom-built lower control arms
Adjustable BMR panhard bar
KYB AGX adjustable rear racing shocks
Eibach lowering street springs
Sold rear sway bar
MSD boost retard
Fuel pressure regulatory
42.5/hr injectors
Felpro gaskets
Hooker Super Comp. 1 ¾ long tube ceramic coated headers
3 in. Flow master exhaust
Moroso 7 quart oil pan
High flow oil pump
Fuel pressure regulator and nitrous gauges mounted on a pillar
BMR Sub frame connectors
BMR Strut tower brace
Wolfe racecraft 6pt role cage with swing out doors on both sides
Harwood cowl induction ram air hood
Head and taillight covers
Original rims with Bridgestone RE730 racing tires (90% remaining)
ZO6 17X8.5 front and 18X10 rear wheels with BF Goodrich G-Force fronts and BFG G-force Drag radials on rear with only 20 miles on them
Alpine CDA-7892 head unit
Boston acoustics 6.5 mid and 1 tweet Rally components for front speakers
Kenwood 6.5 Excelon with center mounted tweeter for rears
Rockford Fosgate 200.4 amp for highs
Kicker 300.1 for sub
JL Audio 10 in sub in custom enclosure in rear panel
Custom fit car cover
Pics are at ebay item #130314997342.
Scottylt1
Jan 8, 2015 02:48 PM
cmdeshon
Jan 4, 2015 11:15 AM
Scottylt1
Dec 4, 2014 12:31 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
