Dropping engine out of the bottom
Old Feb 26, 2009 | 09:59 PM
Camaroz28lt1383's Avatar
Well ive pulled lt1s and ls1s throught the top and its a big pain, my dad has a 3.8 firebird 96, and he just did the intake gaskets on it and now the main seal look like it went. Im wanting to drop it out of the bottom for the first time, ive read a lot on here so far, just would like to know everything that needs disconnected, I know the fuel lines, front brake lines, tranny lines out of rad, steering shaft, ive heard you can just take the computer and lay it on the motor, obviously the DS, and exhaust come off, just seeing if im missing any thing. Thank you for your help, Paul.
Old Apr 10, 2009 | 04:29 AM
viper03af's Avatar
i do mine out the tops but if its the rear main seal just drop the trans and replace it
Old Apr 11, 2009 | 08:29 PM
BandDirector Blk98ZM6's Avatar
This book gives step-by-step instructions on how to drop an LS1 out of the bottom...I'd imagine the 3.8 wouldn't be that different:
http://www.amazon.com/How-Build-High...9499641&sr=8-2
This is also another good book:
http://www.amazon.com/Build-High-Per...9499641&sr=8-1
Old May 11, 2009 | 11:52 PM
MINION's Avatar
its really simple
disconnect your harness from the car... leave it attached to the motor. take off all your k member bolts should be like 6. disconnect break lines. attach engine hoist to front of car and lift. watch for wires snagging and such as the body lifts and your motor stays on the k member.
its a lil more complicated than that but not much more.
Alex Barnes
Jan 24, 2015 10:21 PM
sscott
Jan 17, 2015 04:30 PM
nballisru
Dec 14, 2014 05:01 PM
formula218
Dec 2, 2014 04:27 PM
Hoodshaker
Aug 27, 2002 02:32 PM
