1994 Camaro will not start???
My step son has a 94 3.4L camaro it will not start for nothing... I changed plugs, and wired cranked over and sputtered for a few seconds and died. Has not even hinted at trying to start after that... Any suggestion will be helpful.
You can hear the pump turn on then cut off after 4 -5 seconds. Also smells like raw gas when cranking over...
check the fuel pump relay and ur ignition relay/ module....then do the fuel pressure check ...easiest thing to do is check ur relays...had the same problem but fixed with the new relay input
