BBK under drive pulley
Dyno test:
http://www.ws6.com/mod-2.htm
0.7 peak HP, 4.4 avg HP.
You aren't going to save much power because the water pump is not belt driven. Whether is causes charging problems depends to some extent on which tranny you have. 25% U/D might be OK with the 800rpm idle of the M6, but the A4 at 550rpm may show the voltage gauge headed for the red.
stockssn2o
May 25, 2015 08:54 AM
