Alternator rebuilt by Bosch
Old Sep 28, 2008 | 04:02 PM
wbacall's Avatar
I am having a problem with my 94 Z28 charging system & I am beginning to suspect that Bosch rebuilt alternators are not very good. The alternator (140 amp) has been replaced 2 times. The battery is a fairly new Optima and tested good. The battery cables are new. Stock pulleys.
The problem I am having is the voltage at idle drops to 11-11'5 volts.
The car is warmed up and the Idle is at 600 RPM
Stock pulleys
The AC & lights are on.
The voltmeter reads low in the red
The voltage at the battery is 11-11.5 at idle, lights are dim & turn signal slows down.
If I raise the idle just 100 RPM the voltage goes up to normal.
I contacted Bosch and they said it was normal??
Has anybody seen similar problem with Bosch alternator?
Any other ideas?
Thanks!
Old Oct 18, 2008 | 04:31 PM
wbacall's Avatar
Anybody?
Old Oct 18, 2008 | 09:10 PM
camarozz95's Avatar
ehh same thing with me I get the rebuilds from autozone they crap out after about a year I got tired of it and just bought a new one been fine since.
Old Oct 18, 2008 | 10:17 PM
Angelis83LT's Avatar
Stock pulleys
Any other ideas?
Thanks!
the stock alterntor does not charge at idle speed really. at least not at an efficient charge. The reason is simple. how long does a car sit at idle during a drive cycle? not very much. So they basically start a little above idle. All the Alts I have had do that for some reason.
Old Oct 18, 2008 | 10:27 PM
97lt1fanatic's Avatar
i cant say much about bosh i have an o'reilly brand new one but ya i lost an alternator plug driving home one night and it did excatly what u are saying but with much worse effects. but it sounds like the alternator is ****, i'd take it out and take it up to o'riellys i know they can test the alternator by itself. the test's with it in the car arent as accurate, but it's worth a shot.
Old Oct 19, 2008 | 03:45 PM
wbacall's Avatar
Is this true? Does everyone see their volt meter drop into the red when the car is hot and the lights are on?
Old Oct 19, 2008 | 11:59 PM
no my voltometer is reading about 14 its a little high but nothing serious thats after its warm and lights are on.
Old Oct 20, 2008 | 06:58 AM
Not on my car (with stock alt).
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
blaze309
Sep 8, 2015 05:27 PM
