Overdrive Rumble, Checking Fuel Pressure, Over the Valve Wires, and Best Opti???
Old Jul 19, 2008 | 10:01 PM
glenb1991's Avatar
Ok. 4 Main questions right now....
1) Im having a really rough stumble when i put throttle in my overdrive gear. it doesnt really do it in any other gear... ie... 1,2,D. Any ideas, ive been told it could be my OD gear in my tranny... any other ideas???
2) I have also been told it could be my fuel pressure. How would i go about checking this???
3) Ive burnt two wires to the same plug since i did my headers. Where can i buy over the valve wires and looms to hold them???
4)I think my opti is going bad, what is the best opti out there to buy as a replacement... price wise? and links please if possible.
I think thats it for this day of F-Body hell. lol.
Old Jul 19, 2008 | 10:11 PM
canuck94z28's Avatar
Best opti
Since you have a 94 i would look at the MSD opti as it comes w/replaceable cap/rotor/is vented/ and much better materials than the factory junk.Btw are you getting any opti codes like 36/16?I had code 36 and the car had a terrible bog just off idle but now runs strong to redline,no codes,etc.Highly recommended as the price is slightly higher but you don,t want to have to do this job too many times
Old Jul 19, 2008 | 10:26 PM
#2 http://shbox.com/1/4th_gen_tech2.htm...essure_testing
Old Jul 19, 2008 | 10:33 PM
glenb1991's Avatar
i have no way to scan it right now. so i dont know if the opti is throwing codes or not. ill check as soon as i can get a scanner. You guys can cross off number 3. i found them on one of the supporting vendors pages.
any links to the msd opti??
and thanks shoebox.
Old Jul 20, 2008 | 05:30 AM
tlillard23's Avatar
try a search. titles only "opti"
Old Jul 20, 2008 | 07:13 AM
96capricemgr's Avatar
The MSD opti is NOT any better than stock, most of the knowledgable guys who tried i ended up going back to stock. The cap and rotor kit is good though and honestly it is likely that is all you need.
For some reason people refuse to treat the cap and rotor as maintenance items and then curse a perfectly good system as bad when their NEGLECT causes it to act up.
Old Jul 20, 2008 | 07:37 AM
ABA383's Avatar
Get the wire issue sorted out before going after the opti...When I used to burn wires the lurching miss wouldnt be so pronounced until OD when the car was lugging along. I'd suspect if you fix the wires you'll find your problem...As far as optis go Im a big fan of the the Genuine AC Delco over anything else now...The MSD cap/rotor is a nice upgrade, but I have seen too many issues with the MSD opti unit...
I used Taylor Spiro-pros and the made for you wire looms for my OTVC set up...Been on for 3 years with no burnt wires...Taylor also makes a Thundervolt 8.2 wire that is supposed to be good and still fit the made for you looms...I hear that the MSDs work well, too...Its all a matter of preference...
--Alan
Old Jul 20, 2008 | 03:36 PM
glenb1991's Avatar
yea. im looking at the thunderracing otvc kit to replace my current wire aet-up. but i found the cap and rotor kits... and theres a $215 difference between msd and acdelco.... how big a difference is the quality... i live in florida, so we get plenty of rain if that plays in with the vented cap thing... i would rather not spend an extra $215 if there isnt a crazy difference, but then again, i dont think i want to do this job again anytime soon while its still my dd... so i just need one more strong year basically. lol. just long enough to turn 18 and be outta hs.
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
danielbmx
Aug 27, 2002 11:11 PM
Burn_Out
Aug 18, 2002 08:49 AM
