oil pressure drops
Old Jul 9, 2008 | 12:27 PM
Garcia95's Avatar
oil pressure drops
as i said above when i come to a complete stop the oil pressure drops and the check gauges light comes on my car has an oil leak and i check daily to make sure its not on low oil could this be the problem
Old Jul 18, 2008 | 11:56 PM
heavychevy09's Avatar
mine does the same thing, however i dont have an oil leak. not quite sure what causes it though
Old Jul 22, 2008 | 03:34 PM
Garcia95's Avatar
well that makes 2
Old Aug 8, 2008 | 05:22 AM
USAFretired's Avatar
How many mile do you guys have on your cars? I bought my son a 95 3.4 with 136,000 miles on it and had the same issue. After the head gasket went I replaced it then we had a lifter collapse. The problem ended up being worn bearings in the engine not letting it build pressure after the oil thinned out from heating up. We found a engine with 52,000 miles from a junk yard for $500 and put it in. No problems since. The lifters on the old one were so gunked up they were like solid lifters so when I adjusted them the correct way they gave out. When we pulled the engine we found another on broke. As much as I hate to say it you might need to be rebuilt.
Old Aug 8, 2008 | 08:45 AM
Garcia95's Avatar
well i have a 95 3.4 and it had close to 160k so your right its time for an engine rebuit thanks for that info
Old Aug 8, 2008 | 09:51 AM
mdenz3's Avatar
You could try running some 10-40 or maybe even 20-50 oil to milk it a little longer before the rebuild.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
