my first P&P head job 374 castings
Old Feb 21, 2008 | 04:45 PM
transam1577's Avatar
ok so i am currently going to WYOTECH and im in hi-performance and i decided to do a H/C package and my first thought was send them to loyd elliot,then my instructor(drag race engine builder) told me that i could get around the same flow #s as loyd so i agreedto do them. SO he helped me with the first port then let me loose and after about 44 hours i was done,so i made my way to the flow bench. AMAZINGLY I flowed these #s 287/212 on STOCK VALVES @600 lift. i just figured id post to see what you guys thought also i am going to run a cc503 and 1.6 pro mags and other comp cams valvetrain. how do you think it will perform
OHH and i forgot to mention the LE3 heads only flow about 280/195 with LARGER VALVES I AM AMAZED
Old Feb 21, 2008 | 04:48 PM
AHARTZ28's Avatar
what are the lower numbers?
Old Feb 21, 2008 | 04:58 PM
intake lift @100 @200 @300 @400 @500 @550 @600 @650
CFM-------87.5 151.9 203.2 232.4 267.9 279.7 287.6 285.2
Old Feb 21, 2008 | 05:00 PM
speed_demon24's Avatar
Got any pics? And what is the runner size?
Old Feb 21, 2008 | 05:02 PM
i dont have any pics but i will get you guys some ASAP
Old Feb 21, 2008 | 05:15 PM
SS MPSTR's Avatar
congrats - I'm not shocked at all. What does your instructor say?
Old Feb 21, 2008 | 05:22 PM
LOL again he builds drag motors with heads that flow triple what mine made,but he actually wanted me to build up a huge weld so i could go even bigger,but i kept telling this is going to be a DD not a 6 SEC dragster LOL.
Old Feb 21, 2008 | 05:40 PM
white97T/A's Avatar
+1 curous about runner size.
Old Feb 21, 2008 | 05:52 PM
dangalla's Avatar
.2 142/111
.3 199/143
.4 242/177
.5 271/189
.6 278/196
.650 280/199
thats only le2 #'s
pretty good flow numbers, but flow numbers are far from everything. i also would like to know the port size.
Old Feb 21, 2008 | 05:53 PM
dangalla's Avatar
sorry but i would doubt his knowlege with the whole bigger is better thing
Old Feb 21, 2008 | 06:53 PM
2000GTP's Avatar
Hmm... I have some 374 castings that should be arriving any day now in the mail. Your instructor and yourself can feel free to practice on them as well.
Old Feb 21, 2008 | 06:57 PM
mdacton's Avatar
don't get too cought up on flow numbers......heads can flow less and make more power
Old Feb 21, 2008 | 07:22 PM
MeanGreen97Z's Avatar
I'd like to see what bench you used... what kind of pipe was on the head? There are several things that can make your head flow more on the bench.
Old Feb 21, 2008 | 07:30 PM
mdacton's Avatar
the main thing is to set it up the exact same when checking it to make sure you don't go backwards....
Old Feb 21, 2008 | 07:38 PM
True... what are the details on how you flowed these heads?
