So im about to burn my car down.
Ok intake was leaking something nasty, so today, i spent all day, pulling it off and cleaning the living crap out of everything, i mean spotless sealing serfaces, everything, done text book. New gaskets, i used "the right stuff" gasket maker for the ends, ran it up a little on the heads to completely seal it.
ok so i crank it up, runs great, no weird sounds, great right?
drive it down the road and i smell burning oil, so i pull over, and look under the car, the entire tranny is covered in motor oil, oil leaking through the bell housing.
Basically oil everywhere.
what did i do wrong?
has this happend to anyone else?
how long did you let it sit before starting it,was silicone dry enough?
is your oil pressure sender leaking?
reach behind the intake and feel the gap where you put the silicone to see if it is oil soaked,can you get it on a lift to look up there?
You probably didn't get the rear of the intake sealed. I've found Permatex "Ultra Copper" RTV works really well at the front and back of the intake. BTW - you have to let the rtv dry before you go drivin.
- even if the bolts fall out they usually stay stuck on- thank god...
I never let mine sit before I drive it and dont have a problem with leaks.
I think the key is to lower the manifold straight down onto the motor. I use a cut up wooden pencil as dowels in the end bolt holes to line it up and drop it straight on. I also use the ultra copper sealan. This method works good for me.
But yeah, find out where the leak is coming from. Could be the back of the valve cover? I recently had to replace mine.
The grey RTV works the best. I have done quite a few of em with that stuff and never had a problem. I use a fairly good amount though. And I always run the rtv up onto the intake gasket about a half an inch.
Jul 4, 2005 05:00 PM
