Loaned computer for LT1
Old Feb 3, 2008 | 07:30 PM
Coasterkid's Avatar
So awhile ago we loaned the computer from our perfectly functioned car (not my idea), to a friend whos care was not perfectly functioning (it was an el camino retrofit). After getting it back, and it running for a short time it now does not run right, and the optispark code is coming up. Is it a possiblity is car or something he did messed up our comp. or is it simply the optispark?
Old Feb 3, 2008 | 07:59 PM
Stl94LT1's Avatar
Sounds like an opti problem to me, not PCM.
Old Feb 3, 2008 | 08:32 PM
2000GTP's Avatar
Was the code present right when you installed the PCM?
Old Feb 3, 2008 | 08:35 PM
Coasterkid's Avatar
the code was not present no
Old Feb 3, 2008 | 08:37 PM
2000GTP's Avatar
If the car is running bad and the code was not present at first, then it is most likely a legit code.
SinisterRacing1
Mar 7, 2015 03:44 PM
InfernalVortex
Jan 17, 2015 09:35 AM
4586
Dec 6, 2014 05:20 PM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
