clearancing oil pan
Old Feb 3, 2008 | 03:17 PM
FlamingChicken's Avatar
clearancing oil pan
just wondering how bad are peoples pan fitting? bought the moroso pan and it doesnt seem close to fitting. i have heard people say you need to clearance the pan with a stroker but in my head i saw the pan fitting and then maybe the crank would hit the pan and need to be clearanced in that spot. it looks like the side of my pan is hitting either the throws or the caps. ill find out tonight and update. What are yalls experience?
Old Feb 3, 2008 | 03:41 PM
JP95ZM6's Avatar
The throws do tend hit on the sides of the pan near the bolt flange, which is where the block is ground for clearance. My Canton pan itself was wide enough, but the crank scrapers, which are near the bolt flange, hit the throws. I bent 'em.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
