new motor HP#s cc503, p&plt1 heads & intake,1.6rr,
i am almost done building my lt1 it is all new bottom end,ported & polished heads & intake,CC503 cam,1.6 pro comp rr rockers,2.02/194 valves,behive springs,comp pushrods and all boltons and thats about it. i was just wandering what my HP#s will look like and aslo TQ at crank and or at wheels. also i was wondering if i shaved the heads to raise compression to about 11.1 how much i might gain from that thanks for the help guys
if i have 11.1 compression and all that you think i will only get about 365rwhp? also i have spent so much money on everything else the only thing a may not have enough for at the moment is headers, how much do you think i will suffer HP wise if i dont have them right now. but if you think i must have them i will try to sroung up enough. also i will post my first start up video for yall when i get done, and first dyno
2.00" are the most the typical for nearly 98% of the valve jobs. Mine are 2.02" on the intake which was an extensive job... more than what most people want to pay since the performance gain isn't worth the expense. But I have future plans...
