coolant level
coolant level
just wondering if anyone knows how high is the coolant normally is in their radiator? is it supposed to be at the top of the neck, at the hole for the steam pipe or radiator reservoir tube? just trying to find out if my cap is bad, not letting the coolant back into the radiator when it cools. it seems like the coolant just goes from the radiator to the overflow tank.
wouldn't you be able to spot a leak if this was the case? Mine has been doing the same thing the OP is talking about.
It won't leak when the radiator is pushing out the excess fluid as the engine warms up. Where is causes a problem is when the radiator cools down, creating a vacuum at the cap, and the vacuum tries to pull coolant up out of the reservoir. It can't pull it up, because air leaks into the crack in the hose, and you get air in your radiator instead of coolant. Same thing would happen if you had the hole in the aluminum tube mentioned in the other post above.
Formula Steve
Sep 19, 2023 08:31 AM
