backfiring/popping while decelerating
When I get off the gas I hear what sounds like the exhaust popping and backfiring but it almost sounds like a chassis noise. I had it up on the lift today and for the life of me I don't see anything that could be rattling around so I am lead to believe it is indeed coming from the exhaust. I pressurized my exhaust system while I was at it and found no leaks minus a pinhole in one of the welds way back ny the rear end. The noise seems to emminate from the front left of the car. It is kinda hard to tell the car is kinda noisy anyways. Any ideas as to what may cause this?
Mine does it too...I belevie i have an exhaust leak and my wideband is saying like 10.9:1 during WOT so im running rich.
My old Kawasaki Zx6R did it when i put a carbon fiber pipe on i loved it
Jay
Jay
Well I don't like it, yeah you can kinda feel it in the floorboard. I want it to go away. Or at least quiet it to a dull roar. It most definatly sounds like unburnt fuel popping in the headers. But why is their unburnt fuel in their in the first place and what do I need to adjust in my PCM to make it go away? More timing in the decel cells? anyone with a possible solution feel free to chime in.
Check your LCA's. Make sure they're tight. It's possible if it's a chassis "clunK" it could be LCA bushings. You might even have a torn tranny mount. Do you notice the shifter move during accel/decel? You shouldn't really feel a backfire through full exhaust.
Well here are some more posts to read.
https://www.camaroz28.com/forums/sho...light=backfire
Mostly more questions and little answers.
I got a lot of decel pop on my car as well. I have an ORY and have a Borla Adjustable exhaust and when I had the Borla fully opened, it would pop loud and often. Now that I closed it up and send all of the exhaust through the muffler, it doesn't pop as often or as loud.
I kinda like it
