Oil pressure problems on new motor HELP :)
Old Jan 21, 2008 | 02:12 PM
Ziggy's Avatar
I've got a problem with this new LT1 motor I've got in my 95Z.
Its got great oil pressure at idle and cruising around its fine. But when i get on it and it revs above 3k it drops to 0. Like a rock.
I'm using a stock pump with the milidon pan and pickup. This one: http://www.jegs.com/webapp/wcs/store...10002_70568_-1
Any ideas? I'm at a loss.
Thanks!
Other details on the motor:
ZZ4 crank
Manley rods
JE blower pistons
Vortech S-trim
Old Jan 21, 2008 | 02:14 PM
Javier97Z28's Avatar
Moderator
How much oil do you have in it? I had the same problem w/ that pan.
I've got the Milodon 30909 with matching Milodon pickup.
I tried running 6.5 quarts w/ that pan, windage made pressure drop like a rock.
I am running 5.5 quarts with a standard height filter and oil pressure has never dropped since.
Old Jan 21, 2008 | 02:34 PM
Ziggy's Avatar
That makes sense!
You may be my new best friend. :P
If it ever stops snowing I'll give that a try!
Old Jan 21, 2008 | 02:56 PM
Moderator
I can almost guarantee that's the problem.
Best of luck
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Z28countrymama
Jan 22, 2015 02:50 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
