Any better wires than MSD's for our cars?
It looks like I finally found my miss. I sprayed some water on my engine bay and I got a nice lightshow out of a few wires. I'm running msd wires that are only a couple years old and they have never been burnt or anything like that. I know the taylors are prone to arcing, but supposidly msd's are better. Should I just replace them with some new MSD's? I have OVC wires so I need cut to length wires.
I went from 2 month old Taylors to MSD wires to solve my arching and ignition issues. My graph was much smoother after the MSD wires. I personally won't run any other wires.
I even run them on my LTCC which many forum posts say is "bad" or "can cause problems." They have been problem free and my motor revs cleanly.
Not sure if this helps any, but my current set is Accel 9000s and they seem
to work just fine. We will see how they hold up with the SLP shortys. I've
got the heads torqued and ordered my pushrods today with a next day
delivery (7.05") so hopefully I'll have them by noon tomorrow. I hope to be
running by late Sunday if I get the PCM on time.
I was using Taylors before the Accells, and had problems with 2 different sets. The Accels have been on there since the header install (~15k miles) and still look like new; No hardening, cracking, or burn marks.
Thomas.
Not to go too far off topic, are the taylors known for having issues? Mine have been on for a little over a year with no issues yet, just trying to set up the budget now if they need to be replaced...
Where do they arch? I know my connections were good and tight.
Thanks...
Thanks...
I've been running the magnecores with taylor fire sleeves with no problems for about 15k miles. I don't know if there are worth the expense, but i kept having trouble with my MSDs melting down.
Really though, i think it comes down to the routing. Putting in plug wires is such a pain that i used to not really think about the placement much. Once i blew the money on the magnecores i was VERY careful how i routed things. It took a little creativity an an extra couiple of hours --- i totally changed up some of the routing an used ties to make sure nothing gets even close to a primary.
