Broken my second Valve Spring - What should I get?
I just broke my second MTI valve spring. A few years ago I broke #1 intake, this time it's #3 exhaust. Last time, MTI had some springs in stock and they sent me a free replacement. This time they very politely said they didn't have any more LT1 springs in the shop. (I'm sure they're Comp parts or something anyway, I doubt they make their own.)
Anyhow they suggested I just replace them all since I'm having issues with them.
I'm running a CC305, w/1.6RR's (so .544 lift). I have a Hydra-rev kit (if that matters). LT4 intake/heads. Stock push rods. Stock lifters.
I really don't want to be mucking with the seats (I don't have time or the tools), so something that'll fit without modification is necessary. Any recommendations on something that has a good track record on that sort of lift?
I'm not familiar with the MTI springs at all. Beehives would be a good choice tho. I dont think they require any work to make them fit and they are good to .600 lift. I have read a few posts tho of some people having trouble with the beehives cracking. But I think it was due to a few bad batches of the springs being sent out. Havent heard anything about it recently.
http://web.camaross.com/forums/showt...hlight=Beehive
Thats the thread discussing the beehive batch failures...
I was thinking about this last night, and I honestly don't know what seats/retainers/locks I have since MTI installed them.
So, I have the first broken spring here on my desk at work, I did some quick measurements with a cheap ruler (micrometer is at home and I'm not walking back to get it):
OD- ~1.25
ID- ~0.875 (could be less if you count the inner spring, but I don't think you do)
PAC springs are (according to http://www.pacracing.com/1218info1.jpg):
OD- 1.29
ID- 0.885
Does it sound like the retainers for A should fit the PAC springs, or should I just play it save and get new seats/retainers/locks while I'm at it?
OD- ~1.25
OD- 1.29
ID- 0.885
OD- ~1.25
OD- 1.29
ID- 0.885
OD- ~1.25
OD- 1.29
ID- 0.885
Measure the OD/ID of the small end (assuming the MTI spring is a Beehive) and I'll tell you.
Perfect, answered my question. The MTI springs aren't beehives so they won't work. I was getting slightly confused about how these springs worked.
Got it, I'll have to get new seats/retainers/locks at the same time.
