10.52 NA Pass 95 396 LT1
Here's a clip of my best pass to date. Unfortunately it's next to a 5.90 1/8th mile car and it makes me look bad. It was my 3rd 10.5X pass of the day and then the techs threw me out - no roll bar. Track conditions were good - 62 degrees, 52% humidity, slight headwind 10 - 15 mph. Other consistent cars were down 1 - 1.5 mph because of the wind.
1.406 60'
6.67 8th @ 102
I drive this car to the track, and then install slicks and remove the bullet mufflers and install header pipe extensions (14" long). The rest is in my sig.
http://video.cardomain.com/Clip.aspx...0470F0B66FB7AB
1.406 60'
6.67 8th @ 102
Now, THATS what I'm talkin' about!!! That's friggin nice to see...Makes me want to go out into the garage and start working on getting mine into the 10s...even just a 10.99999....Again, great job...
--Alan
--Alan
Thanks!
It's a built 4L60E with an ATI 8 inch converter footbraked. The intake is stock and port-matched with a 58mm BBK. I need a cage and some frame reinforcing with some sort of anti roll control or maybe an extreme duty drag sway bar. You will notice if you look closely that the car is twisting badly and barely pulls the wheels. Right now I'm using the stock sway bar with poly bushings, UMI performance torque arm, BMR frame connectors, 90-10's, and air bags.
Nice job!
