10.52 NA Pass 95 396 LT1
Old Aug 9, 2007 | 12:03 PM
chrism400's Avatar
Here's a clip of my best pass to date. Unfortunately it's next to a 5.90 1/8th mile car and it makes me look bad. It was my 3rd 10.5X pass of the day and then the techs threw me out - no roll bar. Track conditions were good - 62 degrees, 52% humidity, slight headwind 10 - 15 mph. Other consistent cars were down 1 - 1.5 mph because of the wind.
1.406 60'
6.67 8th @ 102
I drive this car to the track, and then install slicks and remove the bullet mufflers and install header pipe extensions (14" long). The rest is in my sig.
http://video.cardomain.com/Clip.aspx...0470F0B66FB7AB
Old Aug 9, 2007 | 12:15 PM
camarozz95's Avatar
Very nice
Old Aug 9, 2007 | 12:24 PM
joeSS97's Avatar
Props. Nice job!
Old Aug 9, 2007 | 12:30 PM
clcam97's Avatar
Incredible
Old Aug 9, 2007 | 12:32 PM
Hot94Z28's Avatar
Now get a cage and go back!
Old Aug 9, 2007 | 12:36 PM
96ZCamaro's Avatar
I wish my car were that fast
Old Aug 9, 2007 | 12:37 PM
WestCoast96Z28's Avatar
Sweet....great to see N.A. cars hitting those ETs. I'm guessing you spent a full tank of gas to get down the quarter.
Old Aug 9, 2007 | 12:45 PM
396D1SS's Avatar
very nice! what kind of trans/intake setup are you running?
Old Aug 9, 2007 | 02:48 PM
ABA383's Avatar
Now, THATS what I'm talkin' about!!! That's friggin nice to see...Makes me want to go out into the garage and start working on getting mine into the 10s...even just a 10.99999....Again, great job...
--Alan
Old Aug 9, 2007 | 02:51 PM
chrism400's Avatar
Thanks!
It's a built 4L60E with an ATI 8 inch converter footbraked. The intake is stock and port-matched with a 58mm BBK. I need a cage and some frame reinforcing with some sort of anti roll control or maybe an extreme duty drag sway bar. You will notice if you look closely that the car is twisting badly and barely pulls the wheels. Right now I'm using the stock sway bar with poly bushings, UMI performance torque arm, BMR frame connectors, 90-10's, and air bags.
Old Aug 9, 2007 | 02:55 PM
Javier97Z28's Avatar
Moderator
Big converters and lots of gear in an automatic its how it's done.
Good job chris!
Old Aug 9, 2007 | 03:02 PM
The Engineer's Avatar
Very nice times! What is your race-weight and what does your DA typically run there at your track?
WD
Old Aug 9, 2007 | 07:53 PM
2000GTP's Avatar
Congrats, very nice times.
Old Aug 9, 2007 | 08:24 PM
SS MPSTR's Avatar
That's moving out. Nice job.
Old Aug 9, 2007 | 08:46 PM
lt1-xjs's Avatar
Great job Chris, you're "flyin." I remember about 2 yr ago you ran 11.95 with a "503" cam only, I was in the other lane. 396, nice upgrade!
