Waterpump is done, car getting hot real quick still
So we put in the water pump and we figured out all our mistakes from earlier
We started the car and everything seemed fine but it started getting hot again
There was no grinding noise like previously posted from another post I made so everything seemed fine...and nothing leaking
We think the coolant isn't flowing though
We put in the amount that we think we drained from the radiator and spilling from working on it
but we opened the bleeder screw and nothing happened
The radiator also looked unused
We filled the system at the Resivoir tank instead of through the radiator which could be the problem
lemme know what yall think or what I should check
You have to bleed the system with both bleeder valves at the same time. Also are you sure your fans are coming on? I don't know how filling the system at the resivoir affected this but you should fill from the radiator.
All it will do it come out the overfill tank. It takes a while to bleed the system sometimes. Put coolant in the radiator, overfill, and bleed. Eventually all the air will get out. If not you have other issues.
-Dustin-
-Dustin-
Fill the system by way of radiator cap. The reservoir is NOT designed to distribute coolant into the system with gravity.
Best way to bleed system is (read through all steps before starting):
Open both bleeder screws
Poor coolant into radiator
You will eventually hear a hiss
keep filling to brim of radiator and let it settle down until you can't fill it anymore
it's possible the lower bleeder (on t-housing) will start to trickle fluid.
Close bleeder screws
start engine
have someone watch temp gauge while someone else watches coolant level through radiator
fill radiator as the level falls
when you can't fill anymore, close radiator
let system pressurize while still watching temp gauge carefully
Open t-stat bleeder screw
if it leaks coolant you are good to go. close bleeder screw
if air comes out let the system pressurize again and repeat.
do the same for the top screw.
Don't fill radiator COMPLETELY to the top. You want to allow it some room to expand when the coolant starts to get hot.
Once you see a steady stream of coolant start pissing into the radiator from the steam pipe you know the engine is good for coolant.
Well my internet just went out in the time we were doing this
The haynes manual pretty much told us jack **** for bleeding the system
What we did is just fill up the radiator at intervals since we were unsure of how much we took out since it went everywhere
Poured about half a gallon in started it up and then checked everything
Then poured another half in and checked it again
Eventually no more would go in the radiator, but the resoviour was now empty
We poured in more coolant in the radiator and the resovoir came back to life
We then topped it off in the resovoir and now its running fine
I assume theres probably air in the system by doing it this way
The temperature is doing real good, so what I plan to do is just bleed it when I have time back home and have the supervision of my dad.
Thanks for everyones help though
You should be fine. Check the radiator for the next few days. Just FYI the entire cooling system holds approx 16 quarts. If you didn't drain the block and only drained the radiator and part of the block by taking the w/p off that adds up to about 2 gallons give or take. Good idea to keep track just how much you put in.
So far we put in 1.5 gallons, and its pretty high on the dipstick.
There could still be a 1/2 gallon of air in there
My friend was trying to bleed it with just the one obvious screw while I watched the temperature and that wasn't working...apparently there are two to do in order to bleed it. Nothing was coming out of the screw he was doing...it would sometimes spurt out coolant, but most of the time it wasn't.
But i'm sure I'll figure it out when I get back home
1996LT1Z28
Dec 4, 2014 09:20 PM
Jul 4, 2005 05:00 PM
